[Qgis-developer] WCS and Raster improvements for QGIS
Even Rouault
even.rouault at mines-paris.org
Thu Jul 12 06:51:50 PDT 2012
> Yes - Radim already made a first pass implementation using GDAL WCS
> though he said there were some problems with it - I think the most
> critical being that it doesn't support proxy access (I am speaking
> under correction here as I haven't looked into it in that much detail
> myself).
This should be rather easy to add. It is just a matter of setting the right
option to CPLHTTPFetch() (and thus the curl library), namely :
<li>PROXY=val, to make requests go through a proxy server, where val is of the
form proxy.server.com:port_number
<li>PROXYUSERPWD=val, where val is of the form username:password
Note: They can also already be used by setting the GDAL_HTTP_PROXY and
GDAL_HTTP_PROXYUSERPWD configuration options/environmenet variable, which will
act on all GDAL/OGR drivers that go through the CPLHTTPFetch() function.
I see Radim is already a GDAL committer, so there shouldn't be too much overhead
if he wants to hack in the WCS driver.
> I will let Radim comment on any other issues. I think from
> the project perspective we don't mind too much which approach is used
> if the result is efficient and integrates nicely into QGIS.
> Regards
> Tim
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
