[Qgis-developer] [Qgis-user] GPS Tools strange behavior
Pedro Venâncio
pedrongvenancio at yahoo.com
Sat Jul 14 07:00:14 PDT 2012
Hello Lene,
Thank you for your workaround.
This is a really strange issue... In the first attempt I made with your solution, it worked, but in all other attempts have not... In some of that attempts, it freezes QGIS and in other it shows the message "The layer (...) is not a valid layer and can not be added to the map"...
Best regards,
Pedro
----- Original Message -----
Hi
I´ve had the same errors. I have a funny workaround.
Try to change the line in "Waypoint download". %babel -w -i garmin -o gpx "%in" "%out"
Delete the " "
And Update
Then Set the " " again and update
Then it should work.......
Regards
Lene Fischer
________________________________________
Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] på vegne af Pedro Venâncio [pedrongvenancio at yahoo.com]
Sendt: 14. juli 2012 12:31
Til: qgis-developer at lists.osgeo.org; qgis-user at lists.osgeo.org
Emne: [Qgis-user] GPS Tools strange behavior
I'm trying to download data from a Garmin GPSMAP 60CS with the GPS Tools and I'm faced with a strange and erratic behavior. I can not find a pattern.
I leave here a screencast: http://goo.gl/lofgh
With gpsbabel from the command line, everything works fine.
With the GPS Tools, using the arguments %babel and %out, it does not work, as you can see in the screencast, or because it freezes QGIS, or because it shows the message "The layer (...) is not a valid layer and can not be added to the map".
Putting the full command on the "Waypoint download" field (gpsbabel -w -i garmin -o gpx -f usb: -F /home/pedro/waypoints/wpt2.gpx), it works sometimes, while other times it downloads the data and creates the .gpx file, but freezes and the only option is to force close the tool, which makes QGIS crash.
Has anyone had this problem?
I am using Xubuntu 12.04 and QGIS master.
Thanks!
Best regards,
Pedro Venâncio
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
