[Qgis-developer] New adv labeling freeze-thaw tools
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon Jul 16 01:18:30 PDT 2012
Hi Larry
Excellent work, thank you!
The freeze/thaw tool will be a great addition to the label tool bar.
I wonder if the tool could also be active if x/y is data defined and
rotation not (currently, x/y/rotation need to be data defined to use the
tool).
On a detail level, in QgsMapToolFreezeLabels::highlightLabel you could
probably use QgsMapRenderer::mapToLayerCoordinates to transform the
rectangle (instead of mCoordTransform ).
Regards,
Marco
Am 16.07.2012 05:31, schrieb Larry Shaffer:
> Hi,
> The current large-format project I'm working on requires me to layout,
> for print, thousands of labels. So I spent the last couple of days
> making two new tools for the advanced labeling toolbar that allow the
> user to interactively 'freeze' (write coords and rotation info to
> attribute table) and 'thaw' (revert from data-defined to dynamic) any
> rendered labels.
> *Show Frozen Labels*
> This tool highlights frozen labels for all visible layers. Blue
> highlighted labels are frozen, green are frozen and editable (parent
> layer's in edit mode).
> *Freeze/Thaw Labels*
> This tool allows the user to interactively choose, by single or
> marquee selection, labels to freeze or thaw. The in-memory attribute
> table is immediately updated and results shown to user. This tool
> allows the user to interactively manipulate the PAL labeling engine to
> find the best solutions for their frozen labels.
> Since the topic and how the tool interacts with the labeling engine is
> more complicated, I made an intro video. (Note: I haven't had much
> sleep recently, so it's a bit rough.)
> http://vimeo.com/dakotacarto/freezethawlabels
> This is my first C++ project, so I'd be really happy if someone
> audited the code before I squash the commits and send a pull request:
> https://github.com/dakcarto/Quantum-GIS/tree/feature_freeze-thaw-labels
> Only tested on Mac, as of now. Nothing platform-specific about it though.
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120716/236b0bff/attachment.html>
