[Qgis-developer] Announcing raster-pipes-2 branch for testing
Etienne Tourigny etourigny.dev at gmail.com
Wed Jul 18 12:12:18 PDT 2012
Noticed a few issues with the save dialog
1) "format" drop-down is empty
2) cannot select a new file
3) segfault when saving to an existing file
4) It would be nice to have that action in the legend contextual menu,
like for vector layers.
regards,
Etienne
On Wed, Jul 18, 2012 at 3:59 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> That's great news!
> Concerning raster saving - will there be a mechanism for compressing files?
> It would be great if default compression schemes could be chosen for
> different file types, and an option at save time - sort of like image
> editors.
> I had trouble building it with external spatialite, could only get it
> to compile with cmake -DWITH_INTERNAL_SPATIALITE=TRUE - does this
> require a special version of spatialite?
> regards,
> Etienne
> On Wed, Jul 18, 2012 at 12:13 PM, Marco Hugentobler
> <marco.hugentobler at sourcepole.ch> wrote:
>> Hi devs
>> I'd like to announce the branch 'raster-pipes-2' in Radims repository
>> https://github.com/blazek/Quantum-GIS for testing.
>> Radim did a great job in refactoring the process of reading / resampling /
>> reprojecting / displaying / modifying raster layers. Every step is now a
>> subclass of QgsRasterInterface, with the advantage that several steps can be
>> chained in a QgsRasterPipe. Like that, the raster functionality is nicely
>> separated into different classes and it is easy to add/remove elements in
>> the pipe. The iteration over the raster parts is controlled by
>> QgsRasterIterator (because for high-resolution prints or analysis on large
>> datasets, it is impossible to keep everything in memory at once).
>> Please report any issue you find in the branch to the developer mailing
>> list.
>> Besides the changes in code architecture, there is also a new feature in the
>> raster-pipes-2 branch. It is now possible to write through
>> QgsRasterDataProvider (currently only supported by the gdal provider). There
>> is a 'save as...' function also for rasters now (though it is not 100%
>> complete at the moment). There is the option to save a raster in one file or
>> in tiles (the tiles are then saved in one directory and vrt / pyramides are
>> automatically created. Very usefull for saving the contents of a WMS layer).
>> Regards,
>> Marco
>> Dr. Marco Hugentobler
>> Sourcepole -  Linux & Open Source Solutions
>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
