[Qgis-developer] SVG symbols in QGIS with modifiable colors
Otto Dassau
dassau at gbd-consult.de
Thu Jul 19 00:52:30 PDT 2012
I tried to follow the howtos in the web about defining colors for svg with
param(fill), param(outline) and param(stroke-width).
<svg width="100%" height="100%">
<rect fill="param(fill) #ff0000" stroke="param(outline) #00ff00"
stroke-width="param(stroke-width) 10" width="100" height="100"> </rect>
</svg>
I used a copy from the svg /usr/share/qgis/svg/gpsicons/tree.svg. It looks a
little different:
style="font-size:12px;stroke:#000000;stroke-width:3;fill:#a7a5a5;fill-opacity:
1;stroke-miterlimit:4;stroke-dasharray:none;stroke-linejoin:miter;stroke-linecap:butt"
d="M 56.010357,6.2503568 L 30.572857,43.031607 L 37.729107,43.031607 L
23.666607,63.344107 L 33.072857,63.344107 L 18.291607,84.719107 L
46.510357,84.719107 L 46.510357,99.812857 L 65.541607,99.812857 L
65.541607,84.687857 L
All I managed to change is the fill value with the syntax below, but it
doesn't work for stroke and stroke width.
style="font-size:12px;stroke:param(outline);stroke-width:param(stroke-width);
fill:param(fill);fill-opacity:1;stroke-miterlimit:4;stroke-dasharray:none;
65.541607,84.687857
Has the syntax changed? Or how does it work with more complex svgs. I also
created a svg with inkscape, it shows the same syntax as tree.svg.
Thanks a lot
Otto
