[Qgis-developer] Announcing raster-pipes-2 branch for testing
Radim Blazek
radim.blazek at gmail.com
Fri Jul 20 02:10:26 PDT 2012
On Fri, Jul 20, 2012 at 12:26 AM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Yes - I was also thinking about being able to define defaults for
> saving rasters (default format, default compression + options per
> format, tiles) which would be application-wide.
> And this reusable widget could be pre-populated with these options -
> and used in core as well as python plugins. You would create an
> instance of this widget, given a raster layer, and then be able to
> save it.
> I would see this as an expandable component inside each of the
> gdaltools dialogs.
Please keep in mind that other options have to be added to the dialog:
* user defined null values - initially will be filled with layer
transparency values with 100% transparency
* output CRS
Should we use tabs?
I have granted you write access, please work directly in raster-pipes-2.
Radim
> Etienne
> On Thu, Jul 19, 2012 at 7:21 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> On Fri, Jul 20, 2012 at 12:19 AM, Etienne Tourigny
>>> On Thu, Jul 19, 2012 at 4:09 PM, Marco Hugentobler
>>> <marco.hugentobler at sourcepole.ch> wrote:
>>>> Hi Etienne
>>>> Thanks for the feedback, very much appreciated. I've fixed these issues in
>>>> raster-pipes-2 branch now.
>>>> There are still a few things missing in raster saving:
>>>> - write colortable to output dataset
>>>> - format specific options (e.g. compression)
>>>> - dynamic populating of the format combo box (currently hardcoded to
>>>> geotiff)
>>>> - progress indication for tile based saving and possibility to cancel
>>> It just occurred to me that it would be a great thing to implement
>>> this as a widget+class in QgisGui, so that it could be used elsewhere
>>> (e.g. gdaltools, sextante).
>> You mean as a reusable widget like the crs selector? Yes that would be great!
>> Regards
>> Tim
>>> Any way I can help?
>>>> Regards,
>>>> Marco
>>>> On 18.07.2012 21:12, Etienne Tourigny wrote:
>>>>> Noticed a few issues with the save dialog
>>>>> 1) "format" drop-down is empty
>>>>> 2) cannot select a new file
>>>>> 3) segfault when saving to an existing file
>>>>> 4) It would be nice to have that action in the legend contextual menu,
>>>>> like for vector layers.
>>>>> regards,
>>>>> Etienne
>>>>> On Wed, Jul 18, 2012 at 3:59 PM, Etienne Tourigny
>>>>>> That's great news!
>>>>>> Concerning raster saving - will there be a mechanism for compressing
>>>>>> files?
>>>>>> It would be great if default compression schemes could be chosen for
>>>>>> different file types, and an option at save time - sort of like image
>>>>>> editors.
>>>>>> I had trouble building it with external spatialite, could only get it
>>>>>> to compile with cmake -DWITH_INTERNAL_SPATIALITE=TRUE - does this
>>>>>> require a special version of spatialite?
>>>>>> regards,
>>>>>> Etienne
>>>>>> On Wed, Jul 18, 2012 at 12:13 PM, Marco Hugentobler
>>>>>>> Hi devs
>>>>>>> I'd like to announce the branch 'raster-pipes-2' in Radims repository
>>>>>>> https://github.com/blazek/Quantum-GIS for testing.
>>>>>>> Radim did a great job in refactoring the process of reading / resampling
>>>>>>> reprojecting / displaying / modifying raster layers. Every step is now a
>>>>>>> subclass of QgsRasterInterface, with the advantage that several steps
>>>>>>> can be
>>>>>>> chained in a QgsRasterPipe. Like that, the raster functionality is
>>>>>>> nicely
>>>>>>> separated into different classes and it is easy to add/remove elements
>>>>>>> in
>>>>>>> the pipe. The iteration over the raster parts is controlled by
>>>>>>> QgsRasterIterator (because for high-resolution prints or analysis on
>>>>>>> large
>>>>>>> datasets, it is impossible to keep everything in memory at once).
>>>>>>> Please report any issue you find in the branch to the developer mailing
>>>>>>> list.
>>>>>>> Besides the changes in code architecture, there is also a new feature in
>>>>>>> the
>>>>>>> raster-pipes-2 branch. It is now possible to write through
>>>>>>> QgsRasterDataProvider (currently only supported by the gdal provider).
>>>>>>> There
>>>>>>> is a 'save as...' function also for rasters now (though it is not 100%
>>>>>>> complete at the moment). There is the option to save a raster in one
>>>>>>> file or
>>>>>>> in tiles (the tiles are then saved in one directory and vrt / pyramides
>>>>>>> are
>>>>>>> automatically created. Very usefull for saving the contents of a WMS
>>>>>>> layer).
>>>>>>> Regards,
>>>>>>> Marco
>>>>>>> Dr. Marco Hugentobler
>>>>>>> Sourcepole - Linux & Open Source Solutions
>>>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>>>>> Technical Advisor QGIS Project Steering Committee
>>>>>>> _______________________________________________
>>>>>>> Qgis-developer mailing list
>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>> * QGIS programming and support services
>> * Mapserver and PostGIS based hosting plans
>> * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
