[Qgis-developer] QGIS Continuos Integration Testing now available
Nathan Woodrow
madmanwoo at gmail.com
Fri Jul 20 04:11:56 PDT 2012
Very nice. Having continuous integration is good move to stabilising QGIS.
- Nathan
On Fri, Jul 20, 2012 at 9:04 PM, Tim Sutton <lists at linfiniti.com> wrote:
> I have set up a Jenkins job on my server[1] - it will run the tests
> with each push to master. In theory it will notify offenders if they
> break the tests by email but I havent had a case where I can confirm
> that that behaviour works. You can also get an rss feed to the build
> service (to get notices for each test run), or if you run android, you
> can install a little widget on your phone that will show the current
> status.[2] If you are configuring jenkins mood, set the url to [3].
> Build results from jenkins are also automatically submitted to the
> Dash hosted by OTB[4]
> It would be really great to have others setting up Jenkins on
> different platforms (mac & windows in particular), I will document the
> configuration options I used for the job and put that in git soon.
> [1] http://jenkins.linfiniti.com/job/QGIS/
> [2] https://play.google.com/store/apps/details?id=hudson.android.mood&hl=en
> [3] http://jenkins.linfiniti.com
> [4] http://dash.orfeo-toolbox.org/index.php?project=QGIS
> Regards
> Tim
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> Qgis-developer mailing list
