[Qgis-developer] How to change splash screen in QGIS 1.8 and where is the location of that splash acreen in qgis 1.8 ?
Marco Bernasocchi marco at bernawebdesign.ch
Fri Jul 20 05:45:08 PDT 2012
On 07/20/2012 02:35 PM, Nathan Woodrow wrote:
> You can stop it using --nosplash but you can't change it.
> - Nathan
> On Fri, Jul 20, 2012 at 10:31 PM, kranthi kumar
> <kranthikumar6789 at gmail.com> wrote:
>> ok thank you..
>> is there any option to stop the splash screen and through command
>> prompt and allocating the new image as splash screen ?
>> On 20 July 2012 17:59, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>> It doesn't exist on the file system after QGIS is installed, it is
>>> compiled into the application.
>>> - Nathan
>>> On Fri, Jul 20, 2012 at 10:25 PM, kranthi kumar
>>>> Thank you for giving reply....
>>>> actually i am developing one new application,
So you probably build it yourself no? so change the splash before compiling.
>>>>   for that i need to
>>>> change the splash screen.
>>>> in qgis 1.7, splash screen is available in images/splash/splash.png....
>>>> but now i want to change the splash screen in qgis 1.8
>>>>   so please tell where is the exact location of splash screen in qgis
>>>> 1.8 after installed into the system
>>>> thanking you
>>>> On 20 July 2012 17:51, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>>>> The splash screen is complied into the resources of QGIS and currently
>>>>> can't be changed at runtime.  If you need to change it you must
>>>>> recompile QGIS.
>>>>> - Nathan
>>>>> On Fri, Jul 20, 2012 at 10:18 PM, kranthi kumar
>>>>>> please do let me know about my question as soon as possible
as well, it is nice to put the question in the text and not make super
long subjects.
>>>>>> Regards,
>>>>>> B Kranthi Kumar,
>>>>>> Project Engineer,
>>>>>> C-DAC (R & D)-Pune-411007.
>>>>>> _______________________________________________
>>>>>> Qgis-developer mailing list
>>>>>> Qgis-developer at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Regards,
>>>> B Kranthi Kumar,
>>>> Project Engineer,
>> Regards,
>> B Kranthi Kumar,
>> Project Engineer,
Marco Bernasocchi
http://opengis.ch
