[Qgis-developer] QGIS Continuos Integration Testing now available
Tim Sutton lists at linfiniti.com
Fri Jul 20 06:51:59 PDT 2012
Hi
By the way if you keep the Jenkins page open and your speakers on you
will get a nice audio affirmation after each build :-)
Regards
Tim
On Fri, Jul 20, 2012 at 1:29 PM, Sandro Santilli <strk at keybit.net> wrote:
> It's great to see this coming, now up with adding good tests !!
> --strk;
> On Fri, Jul 20, 2012 at 01:04:17PM +0200, Tim Sutton wrote:
>> I have set up a Jenkins job on my server[1] - it will run the tests
>> with each push to master. In theory it will notify offenders if they
>> break the tests by email but I havent had a case where I can confirm
>> that that behaviour works. You can also get an rss feed to the build
>> service (to get notices for each test run), or if you run android, you
>> can install a little widget on your phone that will show the current
>> status.[2] If you are configuring jenkins mood, set the url to [3].
>> Build results from jenkins are also automatically submitted to the
>> Dash hosted by OTB[4]
>> It would be really great to have others setting up Jenkins on
>> different platforms (mac & windows in particular), I will document the
>> configuration options I used for the job and put that in git soon.
>> [1] http://jenkins.linfiniti.com/job/QGIS/
>> [2] https://play.google.com/store/apps/details?id=hudson.android.mood&hl=en
>> [3] http://jenkins.linfiniti.com
>> [4] http://dash.orfeo-toolbox.org/index.php?project=QGIS
>> Regards
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
