[Qgis-developer] QGIS Continuos Integration Testing now available
Tim Sutton lists at linfiniti.com
Fri Jul 20 13:06:23 PDT 2012
Hi
On Fri, Jul 20, 2012 at 5:18 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Tim, this is great!
> Can this integrate with the various builds from qgis.osgeo.osuosl.org
> - or is this one instance only on your server?
> I guess it would have to be installed on the build farm?
The builds could in theory each be in a jenkins instance and triggered
for each platform in the same way as my server is doing it. At some
stage we could have vms or e.g. EC2 instances with each platform and
github can spawn builds on them, then shut them down again. Be a nice
project for someone with time on their hands.
Regards
Tim
> Etienne
> On Fri, Jul 20, 2012 at 8:04 AM, Tim Sutton <lists at linfiniti.com> wrote:
>> I have set up a Jenkins job on my server[1] - it will run the tests
>> with each push to master. In theory it will notify offenders if they
>> break the tests by email but I havent had a case where I can confirm
>> that that behaviour works. You can also get an rss feed to the build
>> service (to get notices for each test run), or if you run android, you
>> can install a little widget on your phone that will show the current
>> status.[2] If you are configuring jenkins mood, set the url to [3].
>> Build results from jenkins are also automatically submitted to the
>> Dash hosted by OTB[4]
>> It would be really great to have others setting up Jenkins on
>> different platforms (mac & windows in particular), I will document the
>> configuration options I used for the job and put that in git soon.
>> [1] http://jenkins.linfiniti.com/job/QGIS/
>> [2] https://play.google.com/store/apps/details?id=hudson.android.mood&hl=en
>> [3] http://jenkins.linfiniti.com
>> [4] http://dash.orfeo-toolbox.org/index.php?project=QGIS
>> Regards
>> Tim
>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>>  * QGIS programming and support services
>>  * Mapserver and PostGIS based hosting plans
>>  * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Skype: timlinux
