[Qgis-developer] Tests for sextante & qgis providers.
Camilo Polymeris
cpolymeris at gmail.com
Fri Jul 20 22:55:16 PDT 2012
Thank you, Tim. That helped a lot.
On Thu, Jul 19, 2012 at 3:38 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Thu, Jul 19, 2012 at 9:36 AM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> On Wed, Jul 18, 2012 at 12:58 AM, Camilo Polymeris <cpolymeris at gmail.com> wrote:
>>> Hello all,
>>> I have had some difficulty with implementing the tests for Sextante,
>>> in particular, using QgsProviderRegistry.
>>> cf: http://code.google.com/p/sextante/source/browse/trunk/soft/bindings/qgis-plugin/src/sextante/tests/qgis_interface.py
>>> The providers seem not to load. Note that the qgis interface stub is
>>> initialized after a call to QgsApplication.initQgis().
>>> If you have any pointers on what I could be doing wrong, it would be
>>> very much appreciated.
>> I didnt have time to look through your code right now (maybe this
>> evening I will have a chance), but try looking at this project where I
>> have implemented a working test suite for a QGIS python plugin.
>> https://github.com/AIFDR/inasafe/tree/master/gui
>> The tests are run automatically whenever a git push happens so you can
>> see what is produced here:
>> http://jenkins.linfiniti.com/job/InaSAFE/
> In particular also look at this
> https://github.com/AIFDR/inasafe/blob/master/gui/utilities_test.py#L58
> which uses an env var 'QGISPATH' to set up the search path for
> providers etc.
> Regards
> Tim
>> Regards
>> Tim
>>> Thank you & regards,
>>> Camilo
>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>> * QGIS programming and support services
>> * Mapserver and PostGIS based hosting plans
>> * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
> Skype: timlinux
