[Qgis-developer] more git nonsense
Larry Shaffer
larrys at dakotacarto.com
Sun Jul 22 16:50:59 PDT 2012
Hi William,
Not sure if you are interested in git GUIs on the Mac, but I have had
very good results working with github.com and the QGIS project
repository using SourceTree [0]. I have had very few reasons to go to
the command line since moving to it (I do commit squashing in
Terminal/BBEdit). Currently free, as well.
http://sourcetreeapp.com/
[0] https://dl.dropbox.com/u/4058089/qgis/sourcetree_qgis.png
Larry
On Sun, Jul 22, 2012 at 5:22 PM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> Ah, the branch -D option is what I want. I think I may have seen this when looking at the documentation, but it sounded like it might affect upstream.
> On Jul 22, 2012, at 6:04 PM, Nathan Woodrow wrote:
>> You should normally push with: git push origin master
>> This will mean only master is pushed, it sounds like you are pushing
>> all your branches. I also normally do: git push origin master
>> --dry-run to see exactly what is getting pushed upstream.
>> No need to reclone anything. If you don't need the 1.7 and 1.8
>> branches just delete them from your local copy using: git branch -D
>> {1.8 branch name}
>> - Nathan
>> On Mon, Jul 23, 2012 at 8:59 AM, William Kyngesburye
>>> I'd like to avoid downloading from scratch.
>>> On Jul 22, 2012, at 5:05 PM, Etienne Tourigny wrote:
>>>> you might want to try 'git push origin master' to make sure it just
>>>> pushes the master branch.
>>>> In any case - maybe fetch a brand new clone to make sure?
>>>> On Sun, Jul 22, 2012 at 7:01 PM, William Kyngesburye
>>>>> Twice today I've push a couple commits (last time was before the 1.8 release), one <100KB and one <1KB, and both times the push has uploaded 11MB. Yet all that appears at github is the changes I made (as I would expect).
>>>>> I wonder if it has something to do with the stale 1.7 and 1.8 branches on my computer? Those keep giving me [rejected] notices and the push ends with an error: failed to push some refs. I don't think I've made any changes to these that haven't been pushed (certainly not the old 1.7 branch).
>>>>> Is there a way to un-checkout branches I'm no longer using? I think I reset my 1.7 copy a while back so I didn't get push errors like this, but something got out of whack again.
>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>> http://www.kyngchaos.com/
>>>>> "I ache, therefore I am. Or in my case - I am, therefore I ache."
>>>>> - Marvin
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> "This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
>>> - The Ruler of the Universe
>>> Theory of the Universe
>>> There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
>>> -Hitchhiker's Guide to the Galaxy 2nd season intro
> [Trillian] What are you supposed to do WITH a maniacally depressed robot?
> [Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
> - HitchHiker's Guide to the Galaxy
