[Qgis-developer] [Qgis-user] Fwd: qgis 1.8 on MAC: Problem with qwt and more
Larry Shaffer
larrys at dakotacarto.com
Mon Jul 23 14:14:34 PDT 2012
On Mon, Jul 23, 2012 at 2:50 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Sorry, I posted the read-only url without testing, seems it doesn't
> work - same thing for other plugins like atlas plugin at
> http://qgis.org/git/atlas.git
> Can someone please fix this? I have no idea what the read-only git url
> is supposed to be.
> The developper git repos is at
> gitosis at qgis.org:valuetool.git
> and the repos browser is at
> http://hub.qgis.org/projects/valuetool/repository
> In the meantime, I added a zip file at
> http://hub.qgis.org/attachments/4719/valuetool-0.4.0.zip
0.40 seems to work fine [0]. Tested on Mac 10.6.8, latest master
build, using Kyngchaos.com's matplotlib 1.1.0-2 Python package install
[1].
[0] http://dl.dropbox.com/u/4058089/qgis/valuetool_0.40.png
[1] http://www.kyngchaos.com/software/python
The 0.36 update causes a crash when checking the graph choice. The
subsequent dialog about building stats will not go away (keeps
returning), eventually leading to a QGIS crash.
Larry
> On Mon, Jul 23, 2012 at 5:37 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
>> On Mon, Jul 23, 2012 at 1:44 PM, Etienne Tourigny
>>> Folks,
>>> I have developped matplotlib support for the valuetool plugin, if qwt
>>> is available it is used as default, but there is an option to use
>>> matplotlib instead. Could people please test it so I can release it,
>>> perhaps as experimental?
>>> It's at the plugin repos http://qgis.org/git/valuetool.git
>> Etienne, I can't seem to clone from that url:
>> [larrys]$ git clone http://qgis.org/git/valuetool.git
>> Cloning into 'valuetool'...
>> fatal: http://qgis.org/git/valuetool.git/info/refs not found: did you
>> run git update-server-info on the server?
>>> I have released a version (0.3.6) with some other bugfixes in the
>>> plugins repos today.
>>> Etienne
>>> On Mon, Jul 23, 2012 at 10:57 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
>>>> Il 23/07/2012 15:56, Werner Macho ha scritto:
>>>>> IMHO this tool is worth to be integrated as a core plugin. But I know
>>>>> that means a lot of work porting it to cpp.
>>>> agreed; it does not need to be ported to C++ to become a core plugin.
>>>> all the best, and thanks.
>>>> Paolo Cavallini - Faunalia
>>>> www.faunalia.eu
>>>> Full contact details at www.faunalia.eu/pc
>>>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
