[Qgis-developer] can't see "offset curve" tool under Windows
Andreas Neumann
a.neumann at carto.net
Tue Jul 24 00:11:53 PDT 2012
Hi Giovanni,
The availability of the curve offset tool depends on the GEOS version
used by QGIS.
You need at least GEOS 3.3x - I believe the current Windows builds come
with GEOS 3.2.x
Andreas
On Mon, 23 Jul 2012 18:45:01 +0100, Giovanni Manghi wrote:
> Hi all,
> I can see the "offset curve" under Linux, but not under Windows, am I
> missing something?
> I have also a doubt about how to use the tool:
> when I click on a line on the bottom left corner of the QGIS windows
> I
> see I can set manually the offset distance, but it doesn't seems to
> have
> any effect. I'm again missing something simple?
> cheers
> -- Giovanni --
> Qgis-developer mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
