[Qgis-developer] Announcing raster-pipes-2 branch for testing
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Wed Jul 25 09:00:27 PDT 2012
Hi all
The branch is merged. Enjoy (and report issues on the bugtracker).
Regards,
Marco
Am 24.07.2012 16:53, schrieb Marco Hugentobler:
> Hi all
> I think it would be a good move to merge the raster-pipes-2 branch
> back to trunk. Ok, I know more instabilities, things to polish, etc.
> But in trunk, it receives more attention and people are more motivated
> to work on it.
> Any objections?
> Regards,
> Marco
> Am 20.07.2012 22:15, schrieb Tim Sutton:
>> Hi
>> On Fri, Jul 20, 2012 at 10:13 PM, Etienne Tourigny
>> <etourigny.dev at gmail.com> wrote:
>>> Ok this is a more general question then - which format(s) should
>>> raster export support?
>> It should support any GDAL raster driver that supports write and that
>> is useable with the active dataset.
>> I was referring to tif only in terms of the default profiles I
>> mentioned.
>> Regards
>> Tim
>>> Etienne
>>> On Fri, Jul 20, 2012 at 5:11 PM, Tim Sutton <lists at linfiniti.com>
>>> wrote:
>>>> Hi
>>>> On Fri, Jul 20, 2012 at 10:07 PM, Etienne Tourigny
>>>>>> One thing that would be really nice is to have
>>>>>> some default profiles:
>>>>>> - options for maximum read performance regardless of disk space
>>>>>> - options for minumum file size regardless of performance
>>>>>> - options for 'middle of the road' between the above two
>>>>> would you have these options for all file types? it could get a
>>>>> little
>>>>> complex, but worth the effort. For now I am implementing 1 default
>>>>> for
>>>>> each driver, which can be defined by the user.
>>>> I was thinking just for tiff as I think it is the most generically
>>>> used.
>>>> Regards
>>>> Tim
>>>>> Etienne
>>>>>> Regards
>>>>>> Tim
>>>>>>>> I have granted you write access, please work directly in
>>>>>>>> raster-pipes-2.
>>>>>>> thanks
>>>>>>> Etienne
>>>>>>>> Radim
>>>>>>>>> Etienne
>>>>>>>>> On Thu, Jul 19, 2012 at 7:21 PM, Tim Sutton
>>>>>>>>> <lists at linfiniti.com> wrote:
>>>>>>>>>> Hi
>>>>>>>>>> On Fri, Jul 20, 2012 at 12:19 AM, Etienne Tourigny
>>>>>>>>>>> On Thu, Jul 19, 2012 at 4:09 PM, Marco Hugentobler
>>>>>>>>>>> <marco.hugentobler at sourcepole.ch> wrote:
>>>>>>>>>>>> Hi Etienne
>>>>>>>>>>>> Thanks for the feedback, very much appreciated. I've fixed
>>>>>>>>>>>> these issues in
>>>>>>>>>>>> raster-pipes-2 branch now.
>>>>>>>>>>>> There are still a few things missing in raster saving:
>>>>>>>>>>>> - write colortable to output dataset
>>>>>>>>>>>> - format specific options (e.g. compression)
>>>>>>>>>>>> - dynamic populating of the format combo box (currently
>>>>>>>>>>>> hardcoded to
>>>>>>>>>>>> geotiff)
>>>>>>>>>>>> - progress indication for tile based saving and possibility
>>>>>>>>>>>> to cancel
>>>>>>>>>>> It just occurred to me that it would be a great thing to
>>>>>>>>>>> implement
>>>>>>>>>>> this as a widget+class in QgisGui, so that it could be used
>>>>>>>>>>> elsewhere
>>>>>>>>>>> (e.g. gdaltools, sextante).
>>>>>>>>>> You mean as a reusable widget like the crs selector? Yes that
>>>>>>>>>> would be great!
>>>>>>>>>> Regards
>>>>>>>>>> Tim
>>>>>>>>>>> Any way I can help?
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Marco
>>>>>>>>>>>> On 18.07.2012 21:12, Etienne Tourigny wrote:
>>>>>>>>>>>>> Noticed a few issues with the save dialog
>>>>>>>>>>>>> 1) "format" drop-down is empty
>>>>>>>>>>>>> 2) cannot select a new file
>>>>>>>>>>>>> 3) segfault when saving to an existing file
>>>>>>>>>>>>> 4) It would be nice to have that action in the legend
>>>>>>>>>>>>> contextual menu,
>>>>>>>>>>>>> like for vector layers.
>>>>>>>>>>>>> regards,
>>>>>>>>>>>>> Etienne
>>>>>>>>>>>>> On Wed, Jul 18, 2012 at 3:59 PM, Etienne Tourigny
>>>>>>>>>>>>>> That's great news!
>>>>>>>>>>>>>> Concerning raster saving - will there be a mechanism for
>>>>>>>>>>>>>> compressing
>>>>>>>>>>>>>> files?
>>>>>>>>>>>>>> It would be great if default compression schemes could be
>>>>>>>>>>>>>> chosen for
>>>>>>>>>>>>>> different file types, and an option at save time - sort
>>>>>>>>>>>>>> of like image
>>>>>>>>>>>>>> editors.
>>>>>>>>>>>>>> I had trouble building it with external spatialite, could
>>>>>>>>>>>>>> only get it
>>>>>>>>>>>>>> to compile with cmake -DWITH_INTERNAL_SPATIALITE=TRUE -
>>>>>>>>>>>>>> does this
>>>>>>>>>>>>>> require a special version of spatialite?
>>>>>>>>>>>>>> regards,
>>>>>>>>>>>>>> Etienne
>>>>>>>>>>>>>> On Wed, Jul 18, 2012 at 12:13 PM, Marco Hugentobler
>>>>>>>>>>>>>>> Hi devs
>>>>>>>>>>>>>>> I'd like to announce the branch 'raster-pipes-2' in
>>>>>>>>>>>>>>> Radims repository
>>>>>>>>>>>>>>> https://github.com/blazek/Quantum-GIS for testing.
>>>>>>>>>>>>>>> Radim did a great job in refactoring the process of
>>>>>>>>>>>>>>> reading / resampling
>>>>>>>>>>>>>>> reprojecting / displaying / modifying raster layers.
>>>>>>>>>>>>>>> Every step is now a
>>>>>>>>>>>>>>> subclass of QgsRasterInterface, with the advantage that
>>>>>>>>>>>>>>> several steps
>>>>>>>>>>>>>>> can be
>>>>>>>>>>>>>>> chained in a QgsRasterPipe. Like that, the raster
>>>>>>>>>>>>>>> functionality is
>>>>>>>>>>>>>>> nicely
>>>>>>>>>>>>>>> separated into different classes and it is easy to
>>>>>>>>>>>>>>> add/remove elements
>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>> the pipe. The iteration over the raster parts is
>>>>>>>>>>>>>>> controlled by
>>>>>>>>>>>>>>> QgsRasterIterator (because for high-resolution prints or
>>>>>>>>>>>>>>> analysis on
>>>>>>>>>>>>>>> large
>>>>>>>>>>>>>>> datasets, it is impossible to keep everything in memory
>>>>>>>>>>>>>>> at once).
>>>>>>>>>>>>>>> Please report any issue you find in the branch to the
>>>>>>>>>>>>>>> developer mailing
>>>>>>>>>>>>>>> list.
>>>>>>>>>>>>>>> Besides the changes in code architecture, there is also
>>>>>>>>>>>>>>> a new feature in
>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>> raster-pipes-2 branch. It is now possible to write through
>>>>>>>>>>>>>>> QgsRasterDataProvider (currently only supported by the
>>>>>>>>>>>>>>> gdal provider).
>>>>>>>>>>>>>>> There
>>>>>>>>>>>>>>> is a 'save as...' function also for rasters now (though
>>>>>>>>>>>>>>> it is not 100%
>>>>>>>>>>>>>>> complete at the moment). There is the option to save a
>>>>>>>>>>>>>>> raster in one
>>>>>>>>>>>>>>> file or
>>>>>>>>>>>>>>> in tiles (the tiles are then saved in one directory and
>>>>>>>>>>>>>>> vrt / pyramides
>>>>>>>>>>>>>>> are
>>>>>>>>>>>>>>> automatically created. Very usefull for saving the
>>>>>>>>>>>>>>> contents of a WMS
>>>>>>>>>>>>>>> layer).
>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>> Marco
>>>>>>>>>>>>>>> Dr. Marco Hugentobler
>>>>>>>>>>>>>>> Sourcepole - Linux & Open Source Solutions
>>>>>>>>>>>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>>>>>>>>>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>>>>>>>>>>>>> Technical Advisor QGIS Project Steering Committee
>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>> Qgis-developer mailing list
>>>>>>>>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>>>>>>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>>>>>>>>>> Tim Sutton - QGIS Project Steering Committee Member (Release
>>>>>>>>>> Manager)
>>>>>>>>>> Please do not email me off-list with technical
>>>>>>>>>> support questions. Using the lists will gain
>>>>>>>>>> more exposure for your issues and the knowledge
>>>>>>>>>> surrounding your issue will be shared with all.
>>>>>>>>>> Visit http://linfiniti.com to find out about:
>>>>>>>>>> * QGIS programming and support services
>>>>>>>>>> * Mapserver and PostGIS based hosting plans
>>>>>>>>>> * FOSS Consulting Services
>>>>>>>>>> Skype: timlinux
>>>>>>>>>> Irc: timlinux on #qgis at freenode.net
>>>>>> Manager)
>>>>>> Skype: timlinux
>>>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>>>> Skype: timlinux
