[Qgis-developer] QgsRasterLayer::bandStatistics
Etienne Tourigny
etourigny.dev at gmail.com
Wed Jul 25 10:41:57 PDT 2012
Hi all,
I had a conversation with Radim about cleaning up the rasterstats
interface in qgsrasterlayer, he is going to work on this soon as well
as make some improvements.
Tim - do you have the time to merge your changes to avoid duplication
and conflicts?
Also, I was wondering if any stats-related functions in qgsrasterlayer
should be removed entirely or kept for backwards-compat for some time
(and internally get the result from rasterdataprovider)?
Etienne
On Mon, Jun 25, 2012 at 5:33 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Mon, Jun 25, 2012 at 9:39 AM, Marco Hugentobler
> <marco.hugentobler at sourcepole.ch> wrote:
>> Hi
>> While fixing the raster issues (in a branch), I'm trying to clean out the
>> raster layer class. Especially, I'm trying to remove symbology related
>> elements from the raster layer (like mRedBandName etc.) and have the
>> symbology only in the renderers .
>> Now I'm not sure what to do with the band statistics. QgsRasterLayer stores
>> and caches QgsRasterBandStats. However I see in the gdal provider that GDAL
>> caches the statistics as well. So my question is if it is ok to remove the
>> statistics related members in QgsRasterLayer and go directly to the raster
>> providers. Or is there a reason to have it on layer level that I missed?
> IIRC there is a slow stats gathering implementation in
> QgsRasterProvider which is virtual and can overloaded by providers
> that are able to get the stats more efficiently. I have some unmerged
> code that cleans up the raster stats rendered output which I will
> commit after you have done your changes, but no I can't think of any
> reason why the provider should not be the canonical source for stats
> and the stats calls in the raster layer class removed.
> By the way I just noticed that the histogram tool in raster properties
> is not working any more for me.
> Regards
> Tim
>> Regards,
>> Marco
>> Dr. Marco Hugentobler
>> Sourcepole - Linux & Open Source Solutions
>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
