[Qgis-developer] Raster colours
Etienne Tourigny
etourigny.dev at gmail.com
Fri Jul 27 16:12:58 PDT 2012
Hi all,
I've pushed to master a simple fix to allow to use the color ramps
from vector styles. It works fine but is limited to current ramps.
Here I were I think things should go, comments are welcome:
- rename "Singleband pseudocolor" to "Singleband color ramp"- although
not sure about that.
- deprecate or remove the QgsFreakOutShader and QgsPseudoColorShader -
they are not used anymore. Is there anything there that should be used
elsewhere?
- rename all the VectorColorRamp classes and widgets to ColorRamp -
this has the potential for disruption but makes things clearer,
because the color ramps can be used by both
- find a way to classify/group/tag color ramps so we can browse them more easily
- add color ramps from 1-band plugin and cpt-city (cited by Giovanni)
- find a way to share color ramps, or make them easily available (see
other email on cpt-city)
Etienne
On Fri, Jul 27, 2012 at 5:38 AM, Marco Hugentobler
<marco.hugentobler at sourcepole.ch> wrote:
> Hi Alex
>>FreakOut also broken. Should we fix them or with discussed new
>>color ramps stuff this doesn't make sense?
> Freak out and pseudocolor are just two special cases of color ramps. I don't
> think it makes sense to implement anything special for those two cases only.
> Regards,
> Marco
> Am 27.07.2012 09:54, schrieb Alexander Bruy:
>> 2012/7/26 Paolo Cavallini <cavallini at faunalia.it>:
>>> The current situation is painful, as the pseudocolor no longer works
>>> without creating classes, choosing interpolation, etc.
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> Qgis-developer mailing list
