[Qgis-developer] can not start qgis after building qgis
李杨 gisyangli at gmail.com
Mon Jul 30 07:01:00 PDT 2012
thks. ./qgis really work. But another problem occured.
seem missing some .so file, I also face this .s0 file missing when build
and install on anther PC.
the shell info is like below:
jack at jack:~/apps/bin$ ./qgis
./qgis: error while loading shared libraries: libqgis_core.so.1.9.0: cannot
open shared object file: No such file or directory
2012/7/30 Nathan iWoodrow <madmanwoo at gmail.com>
> You need to run it like this ./qgis if you want to run it from the bin
> folder.
> - Nathan
> Sent from some fancy phone looking thingo
> From: 李杨
> Sent: 30/07/2012 10:38 PM
> To: qgis-developer at lists.osgeo.org
> Subject: [Qgis-developer] can not start qgis after building qgis
> Hi everyone
> i am a newer here.
>  i run ubuntu 12.04 64bit, and buid after the instruction, but i don't
> know  why can not launch qgis. Seem i successfully build $ install it.
> below is the linux shell:
> -jack at jack:~/apps/bin$ sudo su
> root at jack:/home/jack/apps/bin# qgis
> The program 'qgis' can be found in the following packages:
>  * qgis
>  * qgis-plugin-grass
> Try: apt-get install <selected package>
> root at jack:/home/jack/apps/bin# ls
> qbrowser  qgis  qgis_bench
李杨
北京大学遥感与地理信息系统研究所
419室
北京大学,100871
tel:15210573594
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120730/e4dff914/attachment.html>
