[Qgis-developer] SVG-Icons instead of PNGs?
Andreas Neumann a.neumann at carto.net
Tue Jul 31 04:49:24 PDT 2012
 I think it would be worth a try to use the SVG symbols directly - or at
 least offer the option to use them.
 Andreas
 On Tue, 31 Jul 2012 12:38:07 +0200, G. Allegri wrote:
> Scaling SVG in Inkscapes is known to be problematic. Are you sure
> that
> this applies to Qt SVG scaling too?
> giovanni
> 2012/7/31 Robert Szczepanek
>> Hi Andreas,
>> I made fast SVG downscaling test. Rendered with Inkscape.
>> Second column is shifted vertically by 0,5px.
>> As you can see main problem is "travelling blur" effect. Perhaps
>> there are some smart renderers to overcome this.
>> I would also like to have just one SVG file...
>> Robert
>> On 31.07.2012 10 [3]:30, Andreas Neumann wrote:
>>> Hi Robert,
>>> Thanks for the reply.
>>> Do you have a side-by-side comparison of SVG vs. png and the
>>> rendering
>>> quality somewhere? I wonder if this is still an issue and if it
>>> is - how
>>> much of a problem it really is.
>>> Having just one icon size instead of n different sizes also has a
>>> lot of
>>> advantages. Think about all the new high-dpi devices. These would
>>> benefit a lot from SVG instead of PNG.
>>> Andreas
>>> On Tue, 31 Jul 2012 00:53:40 +0200, Robert Szczepanek wrote:
>>>> Hi Andreas,
>>>> On 29.07.2012 12:22, Andreas Neumann wrote:
>>>>> Regarding the discussion around the icons?
>>>>> How about using SVG icons instead of fixed size png icons?
>>>>> That way one
>>>>> could easily scale the icon sizes on different devices to the
>>>>> preferred
>>>>> scale and taste of the user.
>>>> From my test and literature I found that simple vector scaling
>>>> for
>>>> small size icons (16x16 - 24-24) is not recommended. For higher
>>>> images
>>>> blur effect is not so visible and important.
>>>>> Are there any technical reasons for using PNGs instead of
>>>>> SVGs? I
>>>>> believe the source of the icons is SVG anyway?
>>>>> For my own in house python plugins I always use the SVG
>>>>> icons.
>>>> The main technical reason was image quality. We decided to use
>>>> already rendered images in "native resolution". I know it
>>>> sounds
>>>> stupid in Scalable Vector ... context, but that's the reality.
>>>> Whole version 0.1 of GIS icons was designed in just one SVG
>>>> file. In
>>>> version 0.2 I save them in separate files. So most of the icons
>>>> is at
>>>> the moment available as one file per icon.
>>>> regards,
>>>> Robert
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org [4]
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer [5]
> Links:
> [1] mailto:Qgis-developer at lists.osgeo.org
> [2] http://lists.osgeo.org/mailman/listinfo/qgis-developer
> [3] http://webmail.carto.net/tel:31.07.2012%2010
> [4] mailto:Qgis-developer at lists.osgeo.org
> [5] http://lists.osgeo.org/mailman/listinfo/qgis-developer
> [6] mailto:robert at szczepanek.pl
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
