[Qgis-developer] Unit tests failing - a heartfelt plea
Tim Sutton
lists at linfiniti.com
Fri Jun 15 02:41:58 PDT 2012
Hi All
I just want to make a heartfelt plea that any new code pushed to Git
master should not break tests (at minimum on the platform on which you
are working). If you do radical changes, the test suite should be
updated to accommodate them so that the tests still pass for your
platform when you commit. I would like to see the test suite grow to
encompass as much functionality of QGIS as possible, but it will be
very difficult to maintain them if we commit code that breaks them.
You can always view the state of the last nightly builds here:
http://dash.orfeo-toolbox.org/index.php?project=QGIS
You can test your work before pusing it to master by doing:
make test
make check
or (to share your test results)
make Experimental
Thanks!
Regards
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
