[Qgis-developer] Modifications to dissolve() in fTools
Nathan Woodrow
madmanwoo at gmail.com
Fri Jun 15 08:06:12 PDT 2012
On Sat, Jun 16, 2012 at 12:56 AM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> The opposite makes for a good incremental update process between QGIS
> releases. If fTools is put in the plugins.qgis.org repository, with
> Eliott's tested changes, and incremented to version 0.6.3, users would
> be notified of the update and can install the new version in their
> user plugins directory.
> This means that the plugin/version in master needs to be the same as
> what's in the repository. Then, just before next release of QGIS, the
> core plugin's version is bumped up again, and fTools at
> plugins.qgis.org is removed or hidden from queries.
I'm +1 for this idea. It would be good to be able to update core
plugins of QGIS via the plugin installer, then at each release force
update everyone by removing the one in the installer at release time.
- Nathan
