[Qgis-developer] GGL2 - QGIS integration
G. Allegri giohappy at gmail.com
Mon Jun 18 01:50:36 PDT 2012
> Regarding your question, that is the idea. But actually the Qgis plugin
> will be the server since all the communication is started by the GGL2
> environment. This plugin can be seen as a layer server that provides and
> "stores" (draws) layers: it opens a socket and manages the requests.
Hi Victor,
I've just given a rapid look to the GGL2 site and docs. If I understand it
correctly, GGL2 will run in its own process, and the Qgis plugin will be
the intermediary to expose QGis to GGL2 (through socket communication) as a
"GIS provider".
The GGL2 commands will run on GGL2 which will be able to reference the
layers (and the drawing) on QGis through the plugin. Right?
giovanni
> Regards,
> Víctor.
> 2012/6/18 G. Allegri <giohappy at gmail.com>
> Appart of the UI, a qgis plugin must be created that exchanges
>>> messages with the GGL compiler in order to show results and inform the
>>> compiler about the layers loaded in qgis, etc. This approach already
>>> works in gvSIG. You can see how does it looks like from the user point
>>> of view here[2] and the technical details here[3].
>> AFAICS, GGL will be used as a server to which the Qgis plugin will talk
>> through kind of an XML-RPC protocol, is it right?
>> giovanni
>>> I hope I've answered your question.
>>> Regards.
>>> [1] http://www.gearscape.org/html/course/ejemploggl.htm
>>> [2] http://www.gearscape.org/html/ggl2/tutorials/gis_interaction.html
>>> [3] http://www.gearscape.org/html/ggl2/dev/gis_connection.html
>>> On Mon, Jun 18, 2012 at 9:20 AM, Paolo Cavallini <cavallini at faunalia.it>
>>> wrote:
>>> > Il 18/06/2012 09:14, Fernando González ha scritto:
>>> >> I hope it's interesting for some of you and, of course, any comments
>>> >> of such an active and skilful community are very welcome. Mainly
>>> >> because it's our very first development in python!
>>> > Hi Fernando,
>>> > it looks a very interesting development; thanks for this. Looking
>>> forward to test it.
>>> > How do you plan to integrate it into QGIS?
>>> > All the best.
>>> > Paolo Cavallini - Faunalia
>>> > www.faunalia.eu
>>> > Full contact details at www.faunalia.eu/pc
>>> > Nuovi corsi: http://www.faunalia.it/calendario
>>> > _______________________________________________
>>> > Qgis-developer mailing list
>>> > Qgis-developer at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120618/990a81dc/attachment.html>
