[Qgis-developer] Unit tests failing - a heartfelt plea
Radim Blazek
radim.blazek at gmail.com
Mon Jun 18 10:59:51 PDT 2012
On Mon, Jun 18, 2012 at 5:54 PM, Marco Hugentobler
<marco.hugentobler at sourcepole.ch> wrote:
> Hi Tim
> The raster test passes now (at least on my machine).
Here (85/86 dpi) it also passes 100% OK.
Radim
> Regards,
> Marco
> Am 15.06.2012 11:41, schrieb Tim Sutton:
>> Hi All
>> I just want to make a heartfelt plea that any new code pushed to Git
>> master should not break tests (at minimum on the platform on which you
>> are working). If you do radical changes, the test suite should be
>> updated to accommodate them so that the tests still pass for your
>> platform when you commit. I would like to see the test suite grow to
>> encompass as much functionality of QGIS as possible, but it will be
>> very difficult to maintain them if we commit code that breaks them.
>> You can always view the state of the last nightly builds here:
>> http://dash.orfeo-toolbox.org/index.php?project=QGIS
>> You can test your work before pusing it to master by doing:
>> make test
>> make check
>> or (to share your test results)
>> make Experimental
>> Thanks!
>> Regards
> Dr. Marco Hugentobler
> Sourcepole - Linux& Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> Qgis-developer mailing list
