[Qgis-developer] Changing the Filter of an existing layer
Andreas Neumann a.neumann at carto.net
Wed Jun 20 07:49:46 PDT 2012
 For an existing layer I would like to add/change/remove the WHERE
 filter by script - the same that one would normally set by the query
 builder.
 Do I need to change the QgsDataSourceURI() of that QgsVectorLayer and
 then reload it or is there an easier/more elegant way to change the
 filter of an existing layer?
 Thanks if you have any ideas or even sample code on how to achieve
 this.
 Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
