[Qgis-developer] Changing the Filter of an existing layer
Andreas Neumann a.neumann at carto.net
Wed Jun 20 08:25:48 PDT 2012
 Thanks Anita - easier than I thought.
 Apparently one has to refresh the canvas after setting the
 subsetString.
 Is that how you do it in Time Manager?
 Thanks,
 Andreas
 On Wed, 20 Jun 2012 17:04:49 +0200, Anita Graser wrote:
> Hi Andreas,
> layer.setSubsetString( subsetString ) seems the way to go. At least
> that's what I use in Time Manager ;)
> Best wishes,
> Anita
> On Wed, Jun 20, 2012 at 4:49 PM, Andreas Neumann  wrote:
>> Hi,
>> For an existing layer I would like to add/change/remove the WHERE
>> filter by script - the same that one would normally set by the query
>> builder.
>> Do I need to change the QgsDataSourceURI() of that QgsVectorLayer
>> and then reload it or is there an easier/more elegant way to change
>> the filter of an existing layer?
>> Thanks if you have any ideas or even sample code on how to achieve
>> this.
>> Andreas
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org [1]
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer [2]
> Links:
> [1] mailto:Qgis-developer at lists.osgeo.org
> [2] http://lists.osgeo.org/mailman/listinfo/qgis-developer
> [3] mailto:a.neumann at carto.net
 Andreas Neumann
 Switzerland
