[Qgis-developer] GGL2 - QGIS integration
Fernando González
fergonco at gmail.com
Wed Jun 20 12:41:49 PDT 2012
> backend is in Java and that probably won't change?
sorry for the silence, I'm traveling.
first, the ggl2 compiler is java, and second, it's task is to traduce ggl2
code to java code that actually does the job. this means that the
dependency in java is very strong. i know it is a problem and i don't like
it at all, but porting it to another language would be quite expensive so
we dont consider it at this stage.
I guess the best solution so far is to be content making users install qgis
and ggl separatedly. I don't know if this is a big problem.
regards.
> Regards
> Tim
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120620/d66c8c10/attachment.html>
