[Qgis-developer] Fwd: Bug in Georeferencer
Andrew Miller
A.J.Miller at bcs.org.uk
Fri Jun 22 06:42:13 PDT 2012
I've found a small bug in the Georeferencer plugin.
When I tick the "Use 0 for transparency when needed" and click "Start
georeferencing" against an image that is rotated, I end up with a GeoTiff
that has 3 bands, and black triangles in each corner. However, if I click
"Generate GDAL script" and manually run the generated commands, a 4 band
GeoTiff is created, with Band 4 as an alpha layer and the 4 corner
triangles marked as transparent.
It seems that Georeferencer is not applying the -dstalpha flag when running
gdalwarp (this is the only difference in the generated script when the "Use
0 for transparency when needed" is toggled).
Andrew
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120622/21d1e871/attachment.html>
