[Qgis-developer] www.qgis.org
Alex Mandel
tech_dev at wildintellect.com
Tue Jun 26 08:47:26 PDT 2012
On 06/26/2012 06:09 AM, Paolo Corti wrote:
> On Tue, Jun 26, 2012 at 1:34 PM, Jürgen E. <jef at norbit.de> wrote:
>> What about the other stuff that isn't from Debian? rails? redmine?
>> sphinx maybe?
>> Jürgen
> Hi Jürgen
> the whole django pipe on which django apps are running (plugins,
> pootle, etc...) is configured with virtualenv, so this should not be
> an issue as we are installing stuff using pip (but most likely we will
> need to upgrade to newest Python versions)
> But we will need to re-create the environments and install the applications
> Alessandro and Tim could confirm this as well
> cheers
> p
All, please coordinate this with OSGeo SAC. There are some potential
quirks to upgrading the OS on the virtual machines.
As for the websites, Django in a virtualenv will actually break on the
upgrade when the python version changes, a fresh virtualenv will need to
be created, the correct python packages re-added (pip makes this easy)
and the site files copied in.
Sphinx I think is from backports, redmine should continue to work as is
even if the ruby gets updated slightly.
Thanks,
Alex
