[Qgis-developer] help for a cpp newbie
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Jun 26 23:45:32 PDT 2012
Hi all,
I am (almost) a complete newbie in c++. I am trying to get into it, by
adding a new edit type for vector layers. I am adding something similar
to valuerelation to have multi-attribute edit type (using a join table
and an attribute table).
Basically, I reused almost exactly the same code as valuerelation, at
first. It won't give anything working, but it allows me to learn.
I can compile, but when I run qgis, I have this python error at launch:
ImportError: /home/denis/opt/builds2/share/qgis/python/qgis/core.so:
undefined symbol: _ZN10QgsProject21setTopologicalEditingEb
Then, when I opened the layer properties dialog and I try to change the
edit type, QGIS crashes and I have the following output in the terminal:
symbol lookup error: /home/denis/opt/builds2/bin/qgis: undefined symbol:
_ZN14QgsVectorLayer14multiAttributeEi
I found a similar error on the list
http://lists.osgeo.org/pipermail/qgis-developer/2012-May/020401.html,
but uninstalling and deleting the share directory did nothing.
Does someone has any idea on what could be going wrong?
Thanks
Denis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120627/0529fdd7/attachment.html>
