[Qgis-developer] help for a cpp newbie
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Jun 27 00:16:04 PDT 2012
Hi again,
I did export LD_LIBRARY_PATH=/home/denis/opt/builds2/lib/ before running
QGIS and it worked.
Thanks a lot!!!
One more thing, is there anyway to fix this permanently?
Is there anything I can change in make?
On 06/27/2012 09:07 AM, Marco Hugentobler wrote:
> Hi Denis
> Could it be your qgis executable does not use the libqgis_core.so you
> compiled? If so, you may set the LD_LIBRARY_PATH to point to the
> location of your qgis libs.
> Regards,
> Marco
> Am 27.06.2012 08:45, schrieb Denis Rouzaud:
>> Hi all,
>> I am (almost) a complete newbie in c++. I am trying to get into it,
>> by adding a new edit type for vector layers. I am adding something
>> similar to valuerelation to have multi-attribute edit type (using a
>> join table and an attribute table).
>> Basically, I reused almost exactly the same code as valuerelation, at
>> first. It won't give anything working, but it allows me to learn.
>> I can compile, but when I run qgis, I have this python error at launch:
>> ImportError: /home/denis/opt/builds2/share/qgis/python/qgis/core.so:
>> undefined symbol: _ZN10QgsProject21setTopologicalEditingEb
>> Then, when I opened the layer properties dialog and I try to change
>> the edit type, QGIS crashes and I have the following output in the
>> terminal:
>> symbol lookup error: /home/denis/opt/builds2/bin/qgis: undefined
>> symbol: _ZN14QgsVectorLayer14multiAttributeEi
>> I found a similar error on the list
>> http://lists.osgeo.org/pipermail/qgis-developer/2012-May/020401.html,
>> but uninstalling and deleting the share directory did nothing.
>> Does someone has any idea on what could be going wrong?
>> Thanks
>> Denis
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch <mailto:marco.hugentobler at sourcepole.ch> http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120627/52b69286/attachment.html>
