[Qgis-developer] running qgis from build directory issues
Etienne Tourigny
etourigny.dev at gmail.com
Wed Jun 27 05:52:38 PDT 2012
On Tue, Jun 26, 2012 at 9:15 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi Etienne
> On Tue, Jun 26, 2012 at 1:45 PM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> Hi all,
>> I am running qgis from the build directory (says build-debug inside
>> the source folder) with the command ./bin.output/qgis and I run into 2
>> issues.
>> First I get a pop-up window "Python Error" about missing sextante with
>> text below[1].
>> Disabling sextante did not help but uninstalling sextante resolves it.
>> No other plugins complain.
> This is partly a problem of Sextante and partly QGIS problem:
> - sextante should not try to do anything in __init__.py (e.g. imports)
> - the imports should be moved into classFactory() so that nothing
> happens unless the plugin is explicitly started. (this problem will go
> away once we stop using metadata from __init__.py and only use them
> from metadata.txt)
Filed a bug: http://hub.qgis.org/issues/5878
> - when QGIS is run from build directory, it doesn't copy the internal
> python plugins to the build output directory - that's why sextante is
> complaining about missing plugin installer. We should probably fix
> that in order to provide an environment that is as similar to the
> installed one as possible
Filed here: http://hub.qgis.org/issues/5879
>> Second when I exit qgis I get a segfault :
>> *** glibc detected *** ./output/bin/qgis: corrupted double-linked
>> list: 0x000000000312e6f0 ***
>> ======= Backtrace: =========
>> gdb backtrace below [2]
> Not sure about that, if you are running latest main branch maybe that
> is a side-effect of recent raster refactoring?
> Martin
