[Qgis-developer] Announce: TauDEM plugin for QGIS
Salvatore Larosa
lrssvtml at gmail.com
Fri Jun 29 14:25:44 PDT 2012
Thanks for your great job!
Il giorno ven, 29/06/2012 alle 21.30 +0300, Alexander Bruy ha scritto:
> Hi all and sorry for cross-posting.
> I happy to announce TauDEM provider for QGIS.
> TauDEM [0] is a set of of Digital Elevation Model (DEM) tools for
> the extraction and analysis of hydrologic information from topography
> as represented by a DEM
> An this plugin is a SEXTANTE provider plugin and allows to run
> TauDEM command line tools directly from QGIS using excellent
> SEXTANTE framework [1].
> Plugin available from QGIS Official repository [2]. Before running
> it please install SEXTANTE plugin first. As this is only front-end
> you also need working TauDEM command line tools. Windows
> users can use precompiled binaries and installation instruction
> from project homepage [0]. For Linux users I prepare small
> instruction in README.TauDEM file [3], hope this helps a bit
> until packages for major distributions will be available.
> If you found a bug or want to leave feature request please use
> plugin bugtracker [4]
> [0] http://hydrology.usu.edu/taudem/taudem5.0/index.html
> [1] http://plugins.qgis.org/plugins/sextante/
> [2] http://plugins.qgis.org/plugins/plugins.xml
> [3] https://github.com/alexbruy/sextante-taudem/blob/master/README.TauDEM
> [4] http://hub.qgis.org/projects/sextante-taudem
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
