[Qgis-developer] Qgis 1.7.4 not using '+towgs' proj parameters when
OTF reprojection
Ivan Mincik
ivan.mincik at gmail.com
Fri Mar 9 05:13:31 EST 2012
It seems that latest 'release-1_7' build (and most probably in 1.7.4) is
not using '+towgs' proj parameters when using on-the-fly reprojection.
It is visible when overlaying two layers in different projection where
'towgs' parameter is needed to reproject data accurately. Currently the
error is the same as it would be without specifying 'towgs' parameter.
It was working nicely in older 1.7 releases.
Can anybody confirm ?
Ivan Mincik
