[Qgis-developer] Qgis 1.7.4 not using '+towgs' proj parameters when OTF reprojection
Ivan Mincik ivan.mincik at gmail.com
Fri Mar 9 10:08:30 EST 2012
On 03/09/2012 03:34 PM, Giovanni Manghi wrote:
>> I have found that Qgis is not using 'towgs' only if using one of the
>> projections from installed projection database. If I create custom
>> projection by 'Settings -> Custom CRS' it is working correctly.
> confirmed
Thanks, ticket created: http://hub.qgis.org/issues/5143
Ivan Mincik
