[Qgis-developer] Qgis-mapserver - SLD within WMS GetMap request
Alexandre Dube
adube at mapgears.com
Mon Mar 12 16:51:33 EDT 2012
I'm using qgis-mapserv with QGis 1.7.4 on Ubuntu 10.04, using the
ubuntugis-unstable package.
I'm currently trying to do a WMS GetMap request with a SLD_BODY
parameter set with a simple SLD document. Problem is, I always get the
original style of the features defined in the .qgs file instead of the
one defined in the SLD. Setting a SLD parameter instead pointing to a
copy of the file doesn't do anything either. I looked around for clues
but didn't find any. I attached a copy of the SLD document in question
(without a filter) and with with a filter. My real test-case requires
the filter and it's entirely built using OpenLayers.Format.SLD, so its
content needs to be dynamic from a webmapping client application.
I already got help on IRC from Tim, and he mentioned that Marco
should be the one knowing the answer to my issue. SLD_BODY doesn't seem
to be supported in qgis-mapserv.
Thanks a lot (and a special thanks to Tim for his IRC support),
Alexandre Dubé
Mapgears
www.mapgears.com
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120312/c104c6ca/sld.xml
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120312/c104c6ca/sld-w-filter.xml
