[Qgis-developer] Qgis-mapserver - SLD within WMS GetMap request
Alexandre Dube adube at mapgears.com
Tue Mar 13 08:05:37 EDT 2012
Hi Marco,
   Gotcha.  I'll try the 1_7 branch then.  Do you have an approximative
idea when 1.7.5/1.8 will come out ?
Thanks a lot for your support, much appreciated.
Alexandre
On 12-03-13 07:04 AM, Marco Hugentobler wrote:
> Hi Alexandre
> SLD_BODY works in the developer version (master branch), but not in
> the 1_7_4 version.
> I've backported the fix to the 1_7 branch (don't know if there will be
> a 1.7.5 or if 1.8, which already contains the fix, will be next ).
> Btw, now that we have SLD support directly in the symbology classes
> (thanks to Giuseppe!), I'm going to change QGIS server to use that
> instead of the SLD classes in the server (they are still based on old
> symbology).
> Regards,
> Marco
> On 12.03.2012 21:51, Alexandre Dube wrote:
>> Hi,
>>   I'm using qgis-mapserv with QGis 1.7.4 on Ubuntu 10.04, using the
>> ubuntugis-unstable package.
>>   I'm currently trying to do a WMS GetMap request with a SLD_BODY
>> parameter set with a simple SLD document.  Problem is, I always get
>> the original style of the features defined in the .qgs file instead
>> of the one defined in the SLD.  Setting a SLD parameter instead
>> pointing to a copy of the file doesn't do anything either.  I looked
>> around for clues but didn't find any.  I attached a copy of the SLD
>> document in question (without a filter) and with with a filter.  My
>> real test-case requires the filter and it's entirely built using
>> OpenLayers.Format.SLD, so its content needs to be dynamic from a
>> webmapping client application.
>>   I already got help on IRC from Tim, and he mentioned that Marco
>> should be the one knowing the answer to my issue.  SLD_BODY doesn't
>> seem to be supported in qgis-mapserv.
>> Thanks a lot (and a special thanks to Tim for his IRC support),
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole -  Linux&  Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> marco.hugentobler at sourcepole.ch  http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
Alexandre Dubé
Mapgears
www.mapgears.com
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120313/2537cdb7/attachment.html
