[Qgis-developer] pgversion 0.9.4 and QGIS 1.7.4
Andrés Maneiro
amaneiro at icarto.es
Thu Mar 15 16:21:28 EDT 2012
Hello devs,
I'm trying to test pgversion with QGIS in order to see how it works. While
trying to install I've run in a problem due to missing dependencies (or so I've
been said by the log). Nevertheless, I think I have all the required packages.
See log below. Some thought?
best,
Andrés
Couldn't load plugin 'pgversion' from ['/usr/share/qgis/python',
'/home/amaneiro/.qgis/python', '/home/amaneiro/.qgis/python/plugins',
'/usr/share/qgis/python/plugins',
'/usr/local/lib/python2.6/dist-packages/OWSLib-0.3.2beta-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/ropemode-0.1_rc2-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/JSTools-0.2.2-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/pyramid-1.1a1-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/translationstring-0.3-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/venusian-0.9-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/zope.deprecation-3.4.1-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/zope.configuration-3.7.4-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/zope.component-3.10.0-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/repoze.lru-0.3-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/WebOb-1.0.7-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/PasteScript-1.7.3-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/PasteDeploy-1.5.0-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/Paste-1.7.5.1-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/Mako-0.4.1-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/Chameleon-2.0_rc11-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/zope.schema-3.8.0-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/zope.i18nmessageid-3.5.3-py2.6-linux-i686.egg',
'/usr/local/lib/python2.6/dist-packages/zope.event-3.5.0_1-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/unittest2-0.5.1-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/ordereddict-1.1-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/gsconfig.py-1.0-py2.6.egg',
