[Qgis-developer] Re: properties and prefs dialog section headers different in Master vs. 1.7
Etienne Tourigny etourigny.dev at gmail.com
Sat Mar 17 19:53:26 EDT 2012
When I use the gtk+ theme (not available in qgis-1.7.4) the titles are
not bold and badly justified.  With other themes, justification is ok
but titles are not bold (like you see), and the groups have frames.
I am using Linux Mint 12 (Ubuntu 11.10) with Cinnamon - might be a bug
with gtk+themes there.
Can you try and see if you get this problem with the gtk+ theme?
thanks,
Etienne
On Sat, Mar 17, 2012 at 2:23 PM, Giuseppe Sucameli
<brush.tyler at gmail.com> wrote:
> On Sat, Mar 17, 2012 at 2:43 AM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>>>>> and the justification is weird.  Especially
>>>>> apparent in the "Defalut map appearance..." section of the General tab
>>>>> of the prefs.
>>> No, I cannot confirm this.
>> This happens with long titles, like  "Defalut map appearance..." - you
>> don't get that?
> No, the title is aligned here on Ubuntu 11.04 and QGis master.
> I also tried to resize the dialog but nothing happens.
> Regards.
>>> Regards.
>>>>> The layer properties pages show the same behavior.
>>>>> Is there a setting/style sheet somewhere?
>>>>> Attaching 2 screen shots to illustrate this.
>>>>> regards,
>>>>> Etienne
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Giuseppe Sucameli
> Giuseppe Sucameli
