[Qgis-developer] Scripting QGIS from the outside using Python
pcreso at pcreso.com pcreso at pcreso.com
Sun Mar 18 15:40:51 EDT 2012
Some of Gary Sherman's blogs provide good info on this sort of thing. Like
http://spatialgalaxy.net/2012/01/27/qgis-running-scripts-in-the-python-console/
Brent Wood
--- On Mon, 3/19/12, Martin Dobias <wonder.sk at gmail.com> wrote:
Subject: Re: [Qgis-developer] Scripting QGIS from the outside using Python
To: "Nathan Woodrow" <madmanwoo at gmail.com>
Cc: qgis-developer at lists.osgeo.org
Date: Monday, March 19, 2012, 7:51 AM
On Thu, Mar 15, 2012 at 2:29 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Is it possible to:
> Load QGIS from Python (well I know how to do this using
> QgsApplicaiton.Init())
> Open the project file
> Zoom to a location
> Print the first composer to pdf
> OR render out the map canvas to a image.
Hi Nathan
yes that's all possible from an external python script with PyQGIS,
without actually starting GUI.
> From what I can see the only way is to create a new composer item and pass
> it the composer node from the xml.
No need to play with XML, everything can be done using API, there is
an example in the cookbook:
http://qgis.org/pyqgis-cookbook/composer.html
Martin
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120318/a3a3eb72/attachment.html
