[Qgis-developer] Pyton Script from Qgis Console Help
vinayan
vinayan123 at gmail.com
Tue Mar 20 12:14:24 EDT 2012
Hi all,
I just read about running python scrips from Qgis Console(article by
Gary Sherman
http://spatialgalaxy.net/2012/01/27/qgis-running-scripts-in-the-python-console/).
I am trying rotate each point in a layer based on a center point. I
managed some code by copying from the CadTools plugin(by Stefan
Ziegler). Whenever i run this from qgis console, it crashes the
application. Can somebody point me in the right direction? Please find
the code below. I have to admit that i started python only yesterday.
Note: I am not sure if this is the place to ask this. But i have been
inspired by reading
#!/usr/bin/env Python
"""Load all shapefiles in a given directory.
This script (iteratefeature.py) runs from the QGIS Python console.
From the console, use:
from iteratefeature import Looper
ldr = Looper(qgis.utils.iface)
ldr.LoopXY()
from glob import glob
from os import path
from qgis.core import *
import math
class Looper:
def __init__(self, iface):
"""Initialize using the qgis.utils.iface
object passed from the console.
self.iface = iface
def LoopXY(self):
basePoint=QgsPoint(-121.3140824, 38.63196648)
rotAngle=45
mc = self.iface.mapCanvas()
layer = mc.layer(0)
provider = layer.dataProvider()
feat = QgsFeature()
provider.select()
while(provider.nextFeature(feat)):
#layer.startEditing()
geometry = feat.geometry()
geom1=rotate(geometry,basePoint,rotAngle * math.pi / 180)
layer.changeGeometry(feat.id(), geom1)
#feat.setGeometry(geom1)
#print "X Coord %d: " %geometry.asPoint().x()
#print "Y Coord %d: " %geometry.asPoint().y()
layer.commitChanges()
print "updated %d: " %feat.id()
print
# Rotate script
def rotate(geometry, point, angle):
if angle == 0 or angle == 2 * math.pi or angle == -2 * math.pi:
return geom
p0 = geometry.asPoint()
p1 = QgsPoint(p0.x() - point.x(), p0.y() - point.y())
p2 = rotatePoint(p1, angle)
p3 = QgsPoint(point.x() + p2.x(), point.y() + p2.y())
return QgsGeometry().fromPoint(p3)
# Rotates a single point (centre 0/0).
# (c) Stefan Ziegler
def rotatePoint(point, angle):
x = math.cos(angle)*point.x() - math.sin(angle)*point.y()
y = math.sin(angle)*point.x() + math.cos(angle)*point.y()
return QgsPoint(x, y)
Regards
Vinayan
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120320/ed17a2f5/attachment.html
