[Qgis-developer] gsoc 2012
Noli Sicad
nsicad at gmail.com
Wed Mar 21 18:59:46 EDT 2012
Is SEXTANTE plugin live now?
Anyway, we can browse the python code here.
http://sextante.googlecode.com/svn/trunk/soft/bindings/qgis-plugin/
Noli
On 3/22/12, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> This SEXTANTE plugin is pretty bloody cool. Is it possible to currently
> use the plugin to do work, I can't seem to get any of the modules to pick
> up that I have a layer loaded.
> - Nathan
> On Thu, Mar 22, 2012 at 7:05 AM, G. Allegri <giohappy at gmail.com> wrote:
>> I have given a look to the code. Amazing work Victor!
>> As soon as you stabilize it I will surely test it. Let us know ;)
>> giovanni
>> 2012/3/21 G. Allegri <giohappy at gmail.com>
>> Paolo, SEXTANTE for QGis will be completely in Python, as you can see from
>>> the code in source.
>>> As Victor said, the algorithms hasn't been imported. He has reproduced
>>> the "abstraction" of SEXTANTE, and at the moment the only algorithms that
>>> have been imported are third-party (like fTools) and the bindings to SAGA
>>> and Grass.
>>> giovanni
>>> 2012/3/21 Paolo Cavallini <cavallini at faunalia.it>
>>>> Il 21/03/2012 18:18, G. Allegri ha scritto:
>>>>> Ok, that's what I supposed. We're talking about two different things:
>>>>> your framework and the "geoprocessing framework" that started some
>>>>> time
>>>>> ago. I don't know if Camilo (or others) are still working actively on
>>>>> that.
>>>>> I can imagine that your experience with the "abstraction level"
>>>>> development for SEXTANTE will be an important plus to the development
>>>>> of
>>>>> such a framework... And I hope the development will converge on one of
>>>>> the
>>>>> twos, otherwise it would a waste of resources.
>>>>> The main problem I see is that sextante is in java, and I believe it
>>>> will be very difficult to introduce such an heavy dependency.
>>>> All the best.
>>>> Paolo Cavallini
>>>> See: http://www.faunalia.it/pc
>>>> ______________________________**_________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
