[Qgis-developer] RE: ECW OKKKKK!!!
Ramon Andiñach
custard at westnet.com.au
Sun Mar 25 23:24:16 EDT 2012
Hi Fred,
Other than Frank's package (thanks Frank) was there anything else you needed to do?
I'm getting an unrecognized file type error in QGIS, despite gdalinfo --formats showing ecw on the list.
-ramon.
On 26/03/2012, at 5:47, "Fred ETHEVE" <fred.etheve at wanadoo.fr> wrote:
> Hi, Frank, hi Giovanni, Even, Peter, Barry... hi all,
> You are wonderfull!!!!!!!!!!!!!!
> A very big big thank you for this GDAL 1.9 with ECW
>> From me, my students, and universities of south France
> I hope meet you in Lyon!
> Best regards
> -----Message d'origine-----
> De : fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] De la part de Frank Warmerdam
> Envoyé : vendredi 23 mars 2012 18:39
> À : Fred ETHEVE
> Cc : Jože Detečnik; qgis-developer
> Objet : Re: [Qgis-developer] RE: ECW!!!
> On Fri, Mar 23, 2012 at 6:03 AM, Fred ETHEVE <fred.etheve at wanadoo.fr> wrote:
>> Thank you, all,
>> ECW/win was OK with trunk (1.9.90) until 2 days before new nightly... perhaps, since, gdal used has been 1.9???!!!
> Fred,
> Ah, ok, this is why I asked. I would encourage you to file a ticket against OSGeo4W. I will aim to upgrade the gdal-ecw package to work with the new GDAL 1.9 package (gdal). With luck I could do this over the weekend.
> With all due respect, if you had explained the problem was specifically with OSGeo4W to start I might have already had a plugin built for you.
>> It's time to have an opensource wavelets compression!!!
>> 1) Somebody knows Epsilon CW? Is -it possible with GDAL1.9 linux and win?
>> 2) How to grab one of the builds available at http://www.gisinternals.com/sdk/, have you a method?
> If you find a GDAL 1.9 ECW plugin build from other sources you could drop it in:
> C:/OSGeo4W/bin/gdalplugins/1.9/
> This will only work safely if the plugin is built with the same version of MSVC as GDAL 1.9 (Visual Studio 2008 in this case).
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com light and sound - activate the windows | http://pobox.com/~warmerdam and watch the world go round - Rush | Geospatial Software Developer
> Qgis-developer mailing list
