[Qgis-developer] intersect it plugin
Denis Rouzaud denis.rouzaud at gmail.com
Mon Mar 26 04:42:14 EDT 2012
Hi Paolo,
Did not get it at first time, I'll add two digit in front... so it
should lead to max 99'999m, should be enough. Intersecting greater
distances seems very unlikely!
Yes, I put also this plugin for demo and as a tutorial (also, I have a
good update procedure for the drawers...). Glad a few tested it!
Greetings,
Denis
On 03/23/2012 03:58 PM, Paolo Cavallini wrote:
> Il 23/03/2012 14:32, Denis Rouzaud ha scritto:
>> 2. OK, I thought a little more about this, and I agree. I'll give one more digit (4
>> should be ok, in meter, it's a tenth of a millimeter).
> Maybe this could be used in different contexts for wider areas, so tens of km could
> be appropriate?
>> 3. I am working for a water network company.
>> Basically, drawers are measuring on the field the distance from the network nodes to
>> some building corners or whatever. Then they calculate intersection to have a
>> coordinate for that node. Finally, we keep this info on the map, so if you need the
>> node's position when you go back on the field, you just use the same measures again
>> to locate the node.
>> I don't see think this plugin will be widely spread, I just wondered if someone would
>> be interested. Glad you tried it!
> I think the value of a plugin is not only in what it does, but also in showing what
> can be done, and giving ideas for further developments.
> Thanks!
