[Qgis-developer] import proprietary code inside a python plugin
Noli Sicad nsicad at gmail.com
Mon Mar 26 18:07:46 EDT 2012
GPL + LGPL = OK
    eg. QGIS + SEXTANTE = OK
QGIS + SEXTANTE + your code (GPL or LGPL) = OK
LGPL, MIT, BSD + Proprietory  = OK
   e.g. SEXTANTE + Arcgis = OK
       Spatialite library + iOS = OK.
GPL + Proprietory = ?
    e.g. QGIS + ArcGIS = ?
However,
> Alex post
> 1. QGIS plugin (GPL)
> 2. An Arcpy script (LGPL, MIT, BSD)
QGIS + QGIS plugin (GPL) + Arcpy script (LGPL, MIT, BSD) = might be OK.
Noli
On 3/27/12, G. Allegri <giohappy at gmail.com> wrote:
> Perfect. I find thinking in the terms of process space a clear criterior.
> This makes dynamic and static linking equivalent...
> So, going back to SEXTANTE, it can be given an LGPL license but it cannot
> use non-free code when used through Qgis, while it's free to do it when
> used through, e.g., ArcGIS.
> Please, tell me it's right, otherwise I end the day with another doubt! :)
> giovanni
> 2012/3/26 Vincent Picavet <vincent.ml at oslandia.com>
>> Hi,
>> > Ok, going through hyopthesis things are getting clear:
>> > my plugin is ok until it doesn't load something proprietary in its
>> process
>> > space. As soon as it happens I must be able to provide the source of
>> every
>> > code running in the same process. Right?
>> Right.
>> Importing esri python module falls into that category.
>> Vincent
>> > giovanni
>> > > Hi,
>> > > Le lundi 26 mars 2012 21:32:31, G. Allegri a écrit :
>> > > > Ah, Tim, it's getting clear. Thanks.
>> > > > The key point is distribution, as always with GPL.
>> > > > In my case I won't distribute the ESRI geoprocessing libraries,
>> they're
>> > > > part of the ArcGIS distribution, which is only availbale to users
>> > > > having
>> > > it
>> > > > installed on they're computers.
>> > > > The import satement will success only if the user have the ArcGIS
>> > > > product installed, otherwise it will fail. As a consequence I felt I
>> > > > could
>> > >  freely
>> > > > distribute my plugin as it doesn't strictly require the proprietary
>> > > > side
>> > > to
>> > > > run.
>> > > No you are wrong, as soon as your plugin is distributed and linked
>> > > with
>> > > arcgis, you have to licence everything as GPL and therefore provide
>> > > sources.
>> > > > Doesn't GDAL do the same with ECW?! Ok GDAL are LGPL. Is this the
>> > > > key
>> > > > difference?
>> > > Yes
>> > > > Moreover it doesn't expose the QGis APIs to ArcGIS, and viceversa,
>> > > > so
>> > > > it only bridges the two world to interchange the data.
>> > > Bridging with an import is a link. If you want to exchange data, do it
>> > > without
>> > > the import and separate your modules.
>> > > please re-read my post and mentionned the FSF faq. Everything is in
>> > > there.
>> > > Vincent
>> > > > giovanni
>> > > > 2012/3/26 Tim Sutton <lists at linfiniti.com>
>> > > > > Hi
>> > > > > On Mon, Mar 26, 2012 at 4:52 PM, G. Allegri <giohappy at gmail.com>
>> > > wrote:
>> > > > > > Through the various considerations on this topic there are two
>> > > > > > positions
>> > > > > the
>> > > > > > seems contradictory to me:
>> > > > > > "I did some research on this, and the conclusion is that import
>> is
>> > > > > > functionally and legally equivalent to linking during
>> compilation,
>> > > > > > so everything that imports qgis must be GPL." [1]
>> > > > > So if you plan to distribute although technically possible to link
>> to
>> > > > > a proprietary module, its not legall possible.
>> > > > > > then
>> > > > > > "you can import/link proprietary code into gpl code, provided
>> > > > > > you
>> > > have
>> > > > > > a license to do it."
>> > > > > So if you have the license to ESRI etc. to use their libraries you
>> > > > > are welcome to make yourself a QGIS frontend to ArcSomething, but
>> > > > > you cant legally distribute that.
>> > > > > > They probably mean different things and they're not in
>> > > > > > contradiction.
>> > > > > Being
>> > > > > > an important point to me, could you help in understanding it?
>> > > > > Above is my understanding of those points anyway....
>> > > > > Regards
>> > > > > Tim
>> > > > > > thanks a lot,
>> > > > > > Giovanni
>> > > > > > [1]
>> http://lists.osgeo.org/pipermail/qgis-developer/2012-March/018976.htm
>> > > > > l
>> > > > > > [2]
>> http://lists.osgeo.org/pipermail/qgis-developer/2012-March/019000.htm
>> > > > > l
>> > > > > > 2012/3/26 G. Allegri <giohappy at gmail.com>
>> > > > > >> I think you're right but watch the reality from a worldwide
>> point
>> > > > > >> of
>> > > > > view.
>> > > > > >> I work mostly with foreign countries, not EU/USA. National
>> offices
>> > > and
>> > > > > >> agencies budgets are far beyond the license fees, so they don't
>> > > > > >> care
>> > > > > for it
>> > > > > >> very much. They pay yearly for something that already do the
>> work
>> > > they
>> > > > > need,
>> > > > > >> without having to do contracts for development, define
>> > > > > >> requirements,
>> > > > > etc.
>> > > > > >> This is the reality. In my courses, even those based on ESRI
>> > > software,
>> > > > > >> I always introduce FOSS solutions. Sometimes it raises
>> > > > > >> interest,
>> > > most
>> > > > > >> of
>> > > > > times
>> > > > > >> they don't care. They want the job done, and they don't pay for
>> > > > > >> the
>> > > > > license.
>> > > > > >> That's it.
>> > > > > >> Anyway, if I wouldn't think that (most) of times a free
>> > > > > >> solution
>> > > could
>> > > > > be
>> > > > > >> the best way, I wouldn't be here to talk about it ;)
>> > > > > >> giovanni
>> > > > > >> 2012/3/26 Sandro Santilli <strk at keybit.net>
>> > > > > >>> On Mon, Mar 26, 2012 at 03:31:53PM +0200, G. Allegri wrote:
>> > > > > >>> > I totally agree with you, but reality is a bit different.
>> Many
>> > > > > >>> > agencies,
>> > > > > >>> > corporates, etc. are not considering to leave they're
>> > > > > >>> > infrastructure.
>> > > > > >>> It's their choice, they'll have to bear the consequences of
>> that.
>> > > > > >>> > I suggest solutions to interoperate, not to switch the whole
>> > > thing.
>> > > > > >>> What I'm saying is that it just costs more. And rightly so.
>> > > > > >>> It is no interest of the free software users to make it any
>> > > cheaper,
>> > > > > >>> IMHO.
>> > > > > >>> > It would be easier, and a lot cheeper, if everybody talked
>> one
>> > > > > >>> > language.
>> > > > > >>> +1
>> > > > > >>> > But we have hundreads of languages in the world, and we have
>> to
>> > > > > >>> > deal with
>> > > > > >>> > this.
>> > > > > >>> People grow up learning the language of their mothers.
>> > > > > >>> Nobody has to pay a license to _use_ that language.
>> > > > > >>> And anyone can learn.
>> > > > > >>> We're really not talking about the same thing.
>> > > > > >>> --strk;
>> > > > > > _______________________________________________
>> > > > > > Qgis-developer mailing list
>> > > > > > Qgis-developer at lists.osgeo.org
>> > > > > > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > > > > Tim Sutton - QGIS Project Steering Committee Member (Release
>> > > > > Manager) ==============================================
>> > > > > Please do not email me off-list with technical
>> > > > > support questions. Using the lists will gain
>> > > > > more exposure for your issues and the knowledge
>> > > > > surrounding your issue will be shared with all.
>> > > > > Visit http://linfiniti.com to find out about:
>> > > > >  * QGIS programming and support services
>> > > > >  * Mapserver and PostGIS based hosting plans
>> > > > >  * FOSS Consulting Services
>> > > > > Skype: timlinux
>> > > > > Irc: timlinux on #qgis at freenode.net
