[Qgis-developer] Re: [Qgis-user] SEXTANTE - using calculator tools
from SAGA and GRASS
Pedro Venâncio
pedrongvenancio at yahoo.com
Fri May 4 06:07:41 PDT 2012
Some new observations I've made.
In the example I used yesterday, the raster input was float32.
I tested now with a Int16 raster input and found that the problems are even greater. On one hand, the rasters are coming out of the Grid Calculator float32. Secondly, the extent is always changed, and the resample is always applied, irrespective of whether an odd or even number of layers.
Screencast: http://goo.gl/A1ccn
Using the SAGA GUI, the rasters are also converted to float32, but the Extent is preserved and the resample is not applied.
Screencast: http://goo.gl/ZJhnv
I did these tests on Windows 7 and Debian Wheezy, with the same results.
If someone wants to try to replicate, the original data are from FaunaliaPT and Professor Gonçalves from University of Porto.
http://www.faunalia.pt/downloads/mdt_aster_pt-tm06_GeoTIFF.tar.gz
http://www.fc.up.pt/pessoas/jagoncal/srtm/dem_srtm_pttm06_80m.tif.bz2
Best regards,
Pedro Venâncio
