[Qgis-developer] Help needed for 1st dive into Qgis C++ - Access
and modify the Scale List combo box
kimaidou
kimaidou at gmail.com
Mon May 7 03:51:14 PDT 2012
Hi again,
Here I am :
https://gist.github.com/2627175
I am stuck and really do not understand why. When opening a project,
setting some project scales via the project properties dialog, Applying and
"OK", I get the following errors :
Warning: Object::connect: No such slot QgsScaleComboBox::updateScales()
Warning: Object::connect: (sender name: 'QgsProjectPropertiesBase')
Warning: Object::connect: (receiver name: 'mScaleEdit')
But the slot IS defined.
As you see, I even tried to comment some of the addItem() in
qgsscalecombobox.cpp, but when opening Qgis, these scales remain in the
default scale List...
It must be a dummy typo...
Michael
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120507/79a5a34c/attachment.html
