[Qgis-developer] QGIS 1.8 - check geometry validity not working
a.furieri at lqt.it
a.furieri at lqt.it
Tue May 8 03:17:47 PDT 2012
On Mon, 7 May 2012 18:57:17 +0200, Sandro Santilli wrote:
> How did you import the geometries ?
Serendipity, i.e. finding something useful by pure hazard :-)
Short report explaining this puzzling mystery:
- the disputed Geometry has *two* distinct rings
- the main one is correctly marked in the SHP as the
exterior ring [about 200 vertices]
- the second one has only 4 vertices (i.e. it's a triangle)
and is almost invisible, because is incredibly small (just
few centimeters, measured on the terrain: it looks like
a possible artifact).
this second ring is correctly marked in the SHP to be
an interior ring, and shares a common point with the
exterior ring. nothing forbids an interior ring like this,
so GEOS correctly identifies this Polygon as a valid one.
There was a bug in the SpatiaLite's own SHP loader: on
SpatiaLite the second ring was wrongly assumed to be a second
exterior ring, thus producing a MultiPolygon (two polygons).
But the second polygon was fully contained within the main
one, thus causing GEOS to raise a geometry error.
Conclusion #1: we've found (and resolved) an obscure bug
in SpatiaLite
Conclusion #2: GEOS surely is the better tool to be used
in order to identify any malformed Geometry
Highly recommended ;-)
bye Sandro
p.s.: many thanks to Pasquale, Salvatore and Strk
Il messaggio e' stato analizzato alla ricerca di virus o
contenuti pericolosi da MailScanner, ed e'
risultato non infetto.
