[Qgis-developer] Localization issue in self-compiled QGIS (Ubuntu
12.04)
Werner Macho
werner.macho at gmail.com
Wed May 9 22:42:27 PDT 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 05/10/2012 05:42 AM, Andreas Neumann wrote:
> On further investigation I saw that on Ubuntu 12.04 I see the
> actual fully written language name in the dropdown box (e.g.
> Deutsch), whereas in other systems where it actually works, the
> dropdown box contains language codes (e.g. de). Maybe the mapping
> of the dropdown list values does not work correctly in Ubuntu
> 12.04?
> Andreas
Hi!
You are right .. I tried it last time but appearently missed to fully
switch the language and was satisfied with the written full country.
So there must be something else going on with selecting the language.
It only appears when you are using Qt4.8 because this version is able
to do the abbrev.->Countryname conversion by itself ..
Seems that we have to do it in another way because from my side
written names are much more convenient than abbrevations.
If there will be no fast solution I think we should disable the
conversion for the 1.8 release..
thanks for reporting
kind regards
Werner
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk+rVUMACgkQDAH1YiCxBgngFwCeOWIHpZcmml9/KBtOq4V/t1qf
HKwAn1Fb3HjBc5dx176SUyKi3LKEuQZs
=XhUN
-----END PGP SIGNATURE-----
