[Qgis-developer] show grid on map canvas (similiar to grid used
in composer) - strategy?
John Donovan
mersey.viking at gmail.com
Thu May 10 02:37:11 PDT 2012
I'm very interested in user-definable grid functionality, and I was
planning on implementing something myself for a plugin I'm writing. My
needs are to have the grid set to an arbitrary angle, and ideally to
know which grid square the user has clicked in, relative to a
user-defined origin.
If anyone wants to collaborate, or just has ideas on how best to
implement it, let me know.
Regards,
JD
On 10 May 2012 05:35, Alister Hood <Alister.Hood at synergine.com> wrote:
>> Date: Wed, 9 May 2012 18:00:07 -0300
>> From: Etienne Tourigny <etourigny.dev at gmail.com>
>> Subject: [Qgis-developer] show grid on map canvas (similiar to grid
>> used in composer) - strategy?
>> To: qgis-developer <qgis-developer at lists.osgeo.org>
>> Message-ID:
>> <CA+TxYvPd-5VHoyCX4UHio9X416hKx9ZGeQ5EnnnQVaDP0L9ZCg at mail.gmail.com>
>> Content-Type: text/plain; charset=ISO-8859-1
>> Hi all,
>> I would like to add support to draw a grid on the map canvas, in a way
>> similar to what is done in the map composer (although perhaps without
>> the annotations on the borders).
>> What should be the approach used?
>> 1) plugin or core?
>> 2) rubberbands or basic plot functions triggered after mapCanvas update?
>> I think both drawing strategies are possible using a plugin.
>> It would be best to write in the core, assuming there is sufficient
>> interest in this, but it will take time to trickle down to the stable
>> version (an argument for making it a plugin).
>> I know the current workaround is to create a vector grid with ftools,
>> but that is a little clunky.
>> Any thoughts?
>> Etienne
> Hi,
> I'm not a developer, so this might be a crazy and unnecessary idea, but would it be feasible to create a graticule _provider_?
> This approach would mean that like grids created with ftools, the grid would be created as a layer, but it wouldn't be file based and its extents would automatically update.
> Unlike the approach used in the composer, this would mean:
> - digitising tools could snap to the grid lines.
> - the identify tool could identify the grid lines.
> - the layer could be used for analysis (e.g. you might want to use it to split vector layers).
> - symbology and feature labelling could work just like other vector layers.
> If this was to actually replace the grids in the composer, some improvements to feature labelling would be needed. Some of these would probably be good to have anyway, e.g. an option to label both ends of a line, and an option to align labels horizontally or vertically on the page, rather than N-S or E-W. I guess the difficult one would be providing a way to display labels outside the map frame...
> Regards,
> Alister_______________________________________________
> Qgis-developer mailing list
One of the advantages of being disorderly is that one is constantly
making exciting discoveries. - AA Milne
