[Qgis-developer] show grid on map canvas (similiar to grid used in composer) - strategy?
Etienne Tourigny etourigny.dev at gmail.com
Thu May 10 05:25:21 PDT 2012
On Thu, May 10, 2012 at 9:06 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> I think if QgsPluginLayer is a usable option that would be the way to go, or
> maybe  QgsVectorLayer  but I suspect that you will need a provider for
> that.
Is there a way we can create a QgsVectorLayer in memory, without using
a provider? If not , perhaps we could use a OGR in-memory dataset
('/vsimem/') - is this used currently somewhere in qgis?
Another idea - use a QgsPluginLayer which itself contains a number of
QgsVectorLayers (e.g. polygon + polylines) to remove the need to
create a provider - but this might be cumbersome.
I'm definitely interested in collaborating with others in this!
Etienne
> I think having it show up in the legend is a good idea that way it can be
> turned on and off, styled, and ordered as the user needs.  E.g. sometimes I
> might like to have yellow grid lines rather then black.
> - Nathan
> On Thu, May 10, 2012 at 10:01 PM, Etienne Tourigny <etourigny.dev at gmail.com>
> wrote:
>> On Thu, May 10, 2012 at 1:35 AM, Alister  Hood
>> <Alister.Hood at synergine.com> wrote:
>> >> Date: Wed, 9 May 2012 18:00:07 -0300
>> >> From: Etienne Tourigny <etourigny.dev at gmail.com>
>> >> Subject: [Qgis-developer] show grid on map canvas (similiar to grid
>> >> To: qgis-developer <qgis-developer at lists.osgeo.org>
>> >> Message-ID:
>> >> <CA+TxYvPd-5VHoyCX4UHio9X416hKx9ZGeQ5EnnnQVaDP0L9ZCg at mail.gmail.com>
>> >> Content-Type: text/plain; charset=ISO-8859-1
>> >> Hi all,
>> >> I would like to add support to draw a grid on the map canvas, in a way
>> >> similar to what is done in the map composer (although perhaps without
>> >> the annotations on the borders).
>> >> What should be the approach used?
>> >> 1) plugin or core?
>> >> 2) rubberbands or basic plot functions triggered after mapCanvas
>> >> update?
>> >> I think both drawing strategies are possible using a plugin.
>> >> It would be best to write in the core, assuming there is sufficient
>> >> interest in this, but it will take time to trickle down to the stable
>> >> version (an argument for making it a plugin).
>> >> I know the current workaround is to create a vector grid with ftools,
>> >> but that is a little clunky.
>> >> Any thoughts?
>> >> Etienne
>> > Hi,
>> > I'm not a developer, so this might be a crazy and unnecessary idea, but
>> > would it be feasible to create a graticule _provider_?
>> > This approach would mean that like grids created with ftools, the grid
>> > would be created as a layer, but it wouldn't be file based and its extents
>> > would automatically update.
>> > Unlike the approach used in the composer, this would mean:
>> > - digitising tools could snap to the grid lines.
>> > - the identify tool could identify the grid lines.
>> > - the layer could be used for analysis (e.g. you might want to use it to
>> > split vector layers).
>> > - symbology and feature labelling could work just like other vector
>> > layers.
>> Those are pretty cool ideas!
>> Perhaps a new QgsMapCanvasItem, rather than a provider? Or even a new
>> QgsPluginLayer or QgsVectorLayer, so this is actually a layer? In this
>> case the layer would have to be in the legend, whereas it might be
>> better to hide it from the legend.
>> > If this was to actually replace the grids in the composer, some
>> > improvements to feature labelling would be needed.  Some of these would
>> > probably be good to have anyway, e.g. an option to label both ends of a
>> > line, and an option to align labels horizontally or vertically on the page,
>> > rather than N-S or E-W.  I guess the difficult one would be providing a way
>> > to display labels outside the map frame...
>> This kind of modification would require modifying the core rather than
>> making a plugin I think.
>> > Regards,
>> > Alister
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
